Hi,
I'm used in my video editor to having the cursor move to the point I stop playback.
Can I do that in Audacity with some kind of keystroke?
When I hit spacebar to stop the cursor does not move.
Basically, I like to listen to the playback and split the track at the point I stop it playing. What's the easiest way to do that?
Cheers.
How to have cursor move to stop position
Re: How to have cursor move to stop position
You might be able to go into Audacity, Preferences, Keyboard and assign new functions to the keys.
There are quite a few things that Audacity does that drives video editors nuts. Are you missing the "I" and the "O" keys yet?
While the clip is playing you can set a marker at the current point by pressing [ctrl]+m. That might help a bit.brookie wrote:Basically, I like to listen to the playback and split the track at the point I stop it playing. What's the easiest way to do that?
The fact that the this keyboard shortcut is different from setting a marker while it's stopped ([ctrl]+b) is completely bizarre to me.
