highlighting editing functions
AO9
Post by AO9 » Mon Oct 08, 2012 4:22 pm
I am working in Windows 7. Installed Audacity from the .exe installer.
I am trying to execute edits on the sound using CTRL X; but nothing happens. When I go to the editing menu at the top, the editing commands are not highlighted. Any idea what I have to do to turn on the commands?
Many thanks,
AO
Re: highlighting editing functions
Post by kozikowski » Mon Oct 08, 2012 4:56 pm
Don't you have to select some audio for the edit commands to work? They work fine here. Koz
Post by kozikowski » Mon Oct 08, 2012 4:58 pm
Control-X is 'Remove Audio Cut'. Is that what you wanted? It doesn't arbitrarily run edit commands. Koz
ragnar.jensen
Post by ragnar.jensen » Mon Oct 08, 2012 5:20 pm
AO9 wrote: When I go to the editing menu at the top, the editing commands are not highlighted. Any idea what I have to do to turn on the commands?
This will happen if playback is merely paused. You have to Stop it to enable the editing commands.
Ragnar
