Cassette tape to laptop hardware?
Did you buy a new mixer? Do you need advice? Post here.
Tapehead
Re: Cassette tape to laptop hardware?
Post by Tapehead » Mon Oct 15, 2012 3:04 pm
Thanks for the help, up and running now and quality seems fine on first impressions.
I have a chrome cassette that seems to have slightly more volume on one channel than the other (it was recorded on a 4-track Fostex and mixed down to stereo in 1985 - I didn't keep the master because I figured I'd never be able to remix it all the same again ;) ) what is the easiest way to rectify this, I've read lots of detail here about normalisation v amplify but its stil not entirely clear to me.
I'm using a Technics A-Z7 for playback and double checked with a Sony Walkman Pro and on both machines the same channel comes out lower in volume.
Post by steve » Mon Oct 15, 2012 6:11 pm
You may find it useful to drag the meter toolbar out of its dock position and as wide as possible.
Try turning your headphones round L/R to R/L to check that the imbalance is not in the headphones.
Use the track Pan slider (left side of the track) to adjust the L/R balance. Use both the playback meters and listening to get the pan balance right.
This will be "rendered" when you export the audio track, or you can use "Tracks > Mix and Render" to see the change reflected in the waveform.
Tapehead
Post by Tapehead » Tue Oct 16, 2012 12:43 pm
The imbalance shows up in both the meters and the waveforms. Thanks for the tip on elongating the meter toolbar.
I would guess that adjusting the slider left or right would be the thing to do on these recordings that are already mixed to stereo. Use 'mix & render' for unmixed tracks?
Is it o'k to use the gain slider rather than normalise or amplify to raise the overall volume level a bit once the left/right balance is corrected?
Post by steve » Tue Oct 16, 2012 2:52 pm
Tapehead wrote: I would guess that adjusting the slider left or right would be the thing to do on these recordings that are already mixed to stereo. Use 'mix & render' for unmixed tracks?
If you have multi-track projects, you may want to adjust the pan position of individual tracks, for example if I have 3 tracks, vocal, guitar, bass, then I might want to pan the guitar a little to one side, the bass a little to the other and the vocal dead centre. I would do this using the track gain sliders.
Tapehead wrote:Is it o'k to use the gain slider rather than normalise or amplify to raise the overall volume level a bit once the left/right balance is corrected?
Yes you can do that, though be careful of the peak level. If it hits 0 dB then you will get clipping when you export.
The advantage of "rendering" the track then using Amplify or Normalize is that you can accurately get the peak level to the level that you want it. Typically I normalize to -1 dB before exporting.
Tapehead
Post by Tapehead » Tue Oct 16, 2012 3:01 pm
Thanks for your help steve, I'll play around with various options on some test tracks. Most are multi-tracks already mixed to stereo but I do have some two channel recordings unmixed.
I also have some four channel masters but nothing to play them on - I donated my
Teac deck to charity.
Post by steve » Tue Oct 16, 2012 3:05 pm
Tapehead wrote:I also have some four channel masters but nothing to play them on
If you play "the other side" of the 4 track tapes, do you get 2 channels playing in reverse? If you do, then you could try the Audacity "Reverse" effect. You may find that the reversed tracks gradually drift out of sync with the non-reversed tracks, but it may be close enough to usable results. Use the Time Shift tool to drag tracks left/right to get them as close in sync as you can. http://manual.audacityteam.org/o/man/to ... #timeshift
Tapehead
Post by Tapehead » Wed Oct 17, 2012 2:45 pm
That's a great tip steve, aside from the four channel masters, I've just found a few long 'forgotten' acoustic guitar instrumentals recorded on tracks 3 & 4. I reversed them and they sound fine.
What I'll do is copy over all my cassettes - about 20 sf46's - first and then try rebuilding some four tracks using reverse and time shift.
From initial experiments with audacity, I'm finding the configuration of effects like reverb problematic as I'm used to setting them up in real time. I'm old skool, for example when synths first switched from knobs and sliders to menus and values I didn't get on with them.
I like using Audacity, but is there also software that would allow real time tweaking of effect
plugins once I have everything transferred?
Post by steve » Wed Oct 17, 2012 4:03 pm
Tapehead wrote: I'm finding the configuration of effects like reverb problematic as I'm used to setting them up in real time.
Yes that can be tricky. I find it especially tricky for effects such as Eq, compression, reverb etc.
Most of the effects have "Preview" button, which is some help.
Because of the way that Audacity works it is difficult to implement real time effects without changing the whole nature of the program and losing many of the advantages of "real" editing. However, the developers have been considering the possibility of "real-time preview". That is, settings can be changed in real time while the "preview" audio is playing. Even this is a non-trivial task to program, but I think it would be a massive improvement.
Unfortunately Nyquist effects do not even have the ability to "preview". :(
Tapehead wrote:I like using Audacity, but is there also software that would allow real time tweaking of effect
When I need to use real-time effects I switch over to Ardour (Free, open source, Linux and Mac OS X).
On Linux it is possible to use real-time effects with Audacity by routing the audio through "Jack Audio", but for real-time processing Ardour is more powerful and more convenient.
Similar "DAW" programs are available on Windows and Mac, such as Reaper (Windows - not free but inexpensive and an unlimited trial version), Harrison Mixbus (a commercial product based on Ardour, for Windows, Linux or Mac), Logic (Windows and Mac), Sonar (Windows), Cubase (Windows and Mac), ProTools (Windows and Mac).
Tapehead
Post by Tapehead » Wed Oct 17, 2012 7:38 pm
Thanks, I like Audacity's straightforwardness, but later on I'll try one of the Windows softwares you mentioned for 'real time' effects, I haven't used linux.
Tapehead
Post by Tapehead » Thu Oct 18, 2012 12:16 pm
I couldn't resist experimenting with something relatively easy.
On a source cassette, I found a guitar recording on track 2 and then vocals 'in reverse' on track 3. So I flipped the vocals and managed to successfully slide them into sync using the timeline tool.
It wasn't a long piece and they didn't wander out of time.
