A few beginners questions about Audacity
audacityfanboy
Re: A few beginners questions about Audacity
Post by audacityfanboy » Tue Dec 11, 2012 5:19 pm
Ok soo basicly low pass and high pass is still the best option ? Because even though they are merged into 1 sound source, they still have different frequencies, for instance car is mostly under 400, voice is mostly over 400. Soo if i completely remove, or maybe just lower the sound of those frequencies, it should do the trick in a similiar way that i wanted, right ?
Post by steve » Wed Dec 12, 2012 2:35 am
Yes, filtering may help.
