Here's my interpretation, for what it's worth...
steve wrote:Sorry, I still don't understand what you mean.
"I do have phantom power on my audio interface"
Do you mean:
"The Behringer Xenyx 302 USB has phantom power switched on"
The Behringer Xenyx 302 does not have a switch for phantom power. Phantom power is always on. (I googled for that.)
steve wrote:"i connect my microphone head on the audio interface mic in section."
Do you mean:
"You connect the Audio Technica 2020 to the XLR microphone input on the Behringer Xenyx 302 USB using an XLR microphone cable"
I think nicholashrai is actually connecting the microphone head directly to the mixer, without using a cable. As you can see, its XLR connector is quite narrow, so it's possible to plug it into the mixer input directly.
- AT 2020
- at2020.png (99.39 KiB) Viewed 3026 times
steve wrote:"I want to put my mic with the xlr cable to connect it in the 302usb audio interface but also on my mic stand."
Other than putting the Audio Technica 2020 onto a microphone stand, how is that different to what you just said?
Again, I think nicholashrai just wants to be able to use an XLR cable in order to place the microphone on a stand.
As I understand it the microphone works when plugged directly into the mixer, but not when using an XLR cable.
If that is the case, I would start looking for physical damage in the XLR connectors.
Ragnar
