PreSonus Audiobox - opening Audacity(SOLVED)
Re: Opening the program
Update
I disconnected the internet overnight and Audacity functioned after I reconnected. Now we can be fairly sure that something online is interfering with the sound card. Tonight I will keep the internet running and disable all functions of Norton to narrow that down. If that's the case I may have to have some serious discussion with the Norton folks. Will keep you posted.
Bob H
Bob H
Unless you're behind a firewall that may not be such a good idea. If you connect to the internet via a wifi router then that probably provides a firewall (provided that it is enabled). At the very least, ensure that the Windows firewall is enabled (Norton 360 probably disables it and uses its own).rj7500 wrote:Tonight I will keep the internet running and disable all functions of Norton to narrow that down.
Back to square one. I disabled Norton overnight and the attached screenshot will tell you the results. Honestly I can't see anything else running during the overnight hours. I'm stumped
Bob H
A reboot always solves the problem.
Bob H
screenshot attached
- Attachments
- Screenshot Sept 28.JPG (134.3 KiB) Viewed 1143 times
Incredimail ?rj7500 wrote:Honestly I can't see anything else running during the overnight hours
Ok, but Incredimail runs 24/7 for me. I'll disable it tonight and see.
Thanks for your patience on this one.
Bob H
Bob H
- Quality Assurance
Bob,
I'm not very clear about the symptoms here.
Are you recording overnight? Or do the problems only start in the morning after something happens overnight?
And are the problems that, without reboot, Audacity either does not respond, or the recording breaks up?
And this occurs both with Presonus and the built-in sound device?
The Applications tab of Task Manager only tells you about applications. Click the Processes tab to see what else is running (most will be Windows services that you should not shut down, but shutting down Norton may not shut down all the processes it starts).
What is the other Audacity "application" shown in Task Manager - is it a dialogue box that says "Not Responding"?
Have you tried System Restore?
Symptoms
I record only during daylight hours, my studio is open 9a-5p EST. When I open Audacity in the morning after an overnight respite.......I can open the program, but if I press the record button or any other button for that matter there is no response and if I continue to press I get the ....no response message. There is no response until I reboot the computer.
This occurs without using either device, i cannot get the program into the record mode at all.
Shutting down Norton did nothing and if you can tell me how to shut down mystery processes, please do............Norton won't......
When I record during working hours I shut down every process that is not a critical process. I can do the same overnight but now we're into a process by process investigation...........honestly I'm very close to abandoning Audacity because of it's many problems. The problem i have is that i'm in the midst of a major project and enduring these problems and seeking advice, which you may or may not be able to provide.
- Quality Assurance
OK, but Device Toolbar is still set to a specific input and output device. If you Generate > Tone, without playing, does that respond?rj7500 wrote:Symptoms
When you launch Audacity first thing in the morning, are those two Audacity applications there from the outset, or only when it starts not to respond?
You paid money to Norton. All I can suggest you do is click the "Processes" tab in Task Manager and Google for anything unfamiliar.rj7500 wrote:Shutting down Norton did nothing and if you can tell me how to shut down mystery processes, please do............Norton won't......
Did you try System Restore?rj7500 wrote:When I record during working hours I shut down every process that is not a critical process. I can do the same overnight but now we're into a process by process investigation
Also if a reboot cures it, then you could give yourself some time to investigate further by creating a scheduled task that reboots the computer just before you arrive in the morning. Try this link (I suppose it works the same on XP):
http://answers.microsoft.com/en-us/wind ... 5ce2647148 .
Tone is something I'll try.
Whenever I call up the task manager is looks as you've seen it
