PreSonus Audiobox - opening Audacity(SOLVED)
rj7500
Post by rj7500 » Mon Sep 17, 2012 6:05 pm
Hi
Need some help quickly. When I open Audacity on my desktop and click on the record button, I get a Not Responding message and sure enough the task manager tells me it's not responding. A reboot of Windows helps for one session only whereupon it comes up 'not responding' again.
Running the latest version
Windows XP
Thanks Bob H
Reason: Updated title
Re: Opening the program
Post by kozikowski » Mon Sep 17, 2012 10:13 pm
It takes Windows out?
What are you recording? Or what would you be recording....?
rj7500
Post by rj7500 » Wed Sep 19, 2012 2:14 pm
Hi Koz
Recording voice only, no music. The program just freezes and won't allow me to start a recording then it tells me that Audacity is not responding. Only rebooting the computer makes it return.
Post by Gale Andrews » Thu Sep 20, 2012 3:51 am
Hi Bob
Are you still recording with the PreSonus Audiobox or something else?
Does this also happen when recording with the inbuilt sound device, or with Presonus disconnected?
Anything changed on your computer since the problem started?
Have you tried resetting Audacity Preferences:
http://manual.audacityteam.org/o/man/pr ... tml#stored ?
rj7500
Post by rj7500 » Fri Sep 21, 2012 1:32 am
No changes Gale, still with the Presonus, I will try with the internal device.
rj7500
Post by rj7500 » Wed Sep 26, 2012 2:37 pm
I'm attaching 2 screenshots. This only occurs overnight and I even stopped the overnight backup but i wonder if there's a conflict with my Norton 360. Could that be doing something overnight? As soon as I reboot it comes back and stays that way.
Screenshot 1.JPG (145 KiB) Viewed 1642 times
rj7500
Post by rj7500 » Wed Sep 26, 2012 2:46 pm
Screenshot 2
screenshot 2.JPG (151.93 KiB) Viewed 1641 times
Post by steve » Wed Sep 26, 2012 5:29 pm
It sounds like "something" is interrupting the sound card. If you suspect Norton, try disconnecting from the Internet and running a test with Norton completely shut down.
Post by Gale Andrews » Wed Sep 26, 2012 11:24 pm
Bob,
Is the "Not responding" problem still there, too?
rj7500
Post by rj7500 » Thu Sep 27, 2012 2:45 am
The 'not responding' message happens if i try to click the record button. i'll try disconnecting from the internet tonight and see what happens. Will keep you posted
