Control tracks for various effects
This read-only archive contains discussions from the Adding Feature forum.
New feature request may be posted to the Adding Feature forum.
Technical support is available via the Help forum.
jotti
Re: Control tracks for various effects
Post by jotti » Thu Sep 27, 2012 7:14 pm
Well, I can only imagine the sound data sample by sample. Whatever I want to do, I'd do it sample by sample. Working with "sound" as a concept probably includes a lot of ready made sound functions. I know nothing about them. Guess there are tutorials and manuals.
One thing I'd like to do is something I've discussed here earlier, see this topic. Briefly it's a rotation effect. You rotate a 3D sound curve. The three dimensions are time, left channel and right channel. The rotation happens around the time axis. The mathematics is very simple trigonometry, but it has to be performed on each single sample pair.
Post by steve » Fri Sep 28, 2012 2:24 am
jotti wrote:Working with "sound" as a concept probably includes a lot of ready made sound functions.
Yes there are a lot of ready made functions which have been written in highly optimised (computer generated) C++ code.
jotti wrote:I know nothing about them. Guess there are tutorials and manuals.
Yes, there is extensive documentation: http://wiki.audacityteam.org/wiki/Nyquist_Documentation
jotti wrote:Well, I can only imagine the sound data sample by sample. Whatever I want to do, I'd do it sample by sample.
Let's look at a simple example:
Say we want to increase the value of each sample +0.1
In Nyquist, rather than looping through sample by sample in LISP code and adding 0.1, we can just add 0.1 to the sound.
So if the sound is bound to the symbol "S", then to increment each sample by +0.1 all we need to write is:
Code: Select all
(sum S 0.1)
Taking a slightly more complex example, say we want to multiply each sample value by 1/t where "t" is the time relative to the duration (t=0 at the start, t=1 at the end).
Rather than looping through the sound sample by sample, we can create a control signal that rises from 0 at t=0 to 1.0 at t=1
Code: Select all
(pwlv 0 1 1)
then multiply this control signal by the original sound:
Code: Select all
(mult s (pwlv 0 1 1))
This is hugely simpler to write, much faster and much more efficient than looping through the sound sample-wise.
jotti
Post by jotti » Fri Sep 28, 2012 10:39 am
Ok. I guess all my ideas for sound effects are on such a low level that there are no ready made functions. I'm kind of thinking of creating these "highly optimised (computer generated) C++ code" myself. Though I don't know what this "computer generated" code means. My idea of a rotating stereo effect is one thing I bet there is no Nyquist function for. And if there are some C/C++ libraries for LADSPA plugins, where you operate on "sound" instead of individual samples, I bet there are no rotating stereo effect functions there either.
Post by steve » Fri Sep 28, 2012 12:21 pm
jotti wrote:My idea of a rotating stereo effect is one thing I bet there is no Nyquist function for.
There is no Nyquist function specifically for that task, but I've had a quick read through your old post and implementing your algorithm appears to be quite possible in Nyquist without resorting to sample-wise processing. I expect that it is also possible to program as a LADSPA plug-in.
If you want to develop this effect as a Nyquist effect then I can help you with that.
If you want to develop this effect as a LADSPA effect then I can't offer much help as I don't know C/C++.
