Any quick way to move tracks up and down?
Djard
Post by Djard » Thu Sep 06, 2012 12:11 am
I often find a need to move tracks up and down, such as when synchronizing (compare the spikes in a drum track with those in another rhythm part); but the process is laborious in a large, multitrack project. Is there a way to quickly drag a track up and down or a command to re-order the tracks?
Re: Any quick way to move tracks up and down?
Post by steve » Thu Sep 06, 2012 12:16 am
Try "View menu > Collapse all tracks" (CTRL+shift+C) before you start dragging.
Djard
Post by Djard » Fri Sep 07, 2012 2:39 am
Thank you,
