Poor recording from mixer using RCA to USB cable
harveylax
Post by harveylax » Sun Sep 02, 2012 10:49 am
WINDOWS 7, Installed from .exe file
Hello, I'm using the Numark N4 with a HP Envy 14 Beats edition. I'm absolutely loving it, everything is working perfectly and im improving all the time with mixes and tricks etc.
When I hit record and play it back, the sound is pretty quiet, low quality, there's a loud hum in the background especially during silences and there's almost no bass at all.'
So farI've; changed the sample rate to 16 bit and 44.1 khz (which is what the 2 rca cable to usb input states it works at even though my laptop works at 64 bit...is that the right thing to do?); altered the input levels and record levels on all control interfaces (windows volume mixer, beats audio, recording devices, my mixer and audacity); switched between MME and windows direct sound; checked for updated drivers on all sound hardware: all to no avail.
The strange thing is, when i play an mp3 from windows media player, and change the audio input record device on audacity to the n4, the sound is perfect, but if i try recording from the n4 usb input/output with using serato it does not record anything.
Is the problem that the n4 inbuilt soundcard is not good enough? Would buying an external sound card work with the n4?
My system is a 6 gig RAM quad core i7 processor running at 2.2 Ghz, but im not sure what the soundcard is like though.
If you could help me get to a point where i can record my mixes in a good quality I would be incredibly grateful. I've been strugging with this problem for aleast three weeks now and i just cannot work it out.
Thanks, Harvey.
Re: Poor recording from mixer using RCA to USB cable
Post by kozikowski » Sun Sep 02, 2012 6:26 pm
I'm more than even sure I know what the problem is in a fuzzy, 10,000 foot view sense, but not in your particular case. You may have run out of sound pathways.
Here's my view of the system (which I'm sure is wrong).
You scratch, match beats, cross fade and overlay music on your two "turntables", mix in live microphone also plugged into the turntable system, monitor the show and pre-listen with headphones plugged into the turntable system and send your show out to the stacks of QSC power amplifiers and killer JBL sound system in the club also from the turntable system. The computer is hanging off the USB port on the back of the turntable system purely for recording in whatever software package you choose, Audacity in this case.
Did I hit it?
harveylax
Post by harveylax » Tue Sep 04, 2012 12:36 pm
Hi, thanks for the reply.
Im not quite sure what you mean however, maybe i didnt explain myself properly.
My set up is Laptop playing tunes through Serato Dj intro ===USB===> Numark N4 controller ===>booth ouput: 2 x RCA converter into USB ==> into the same laptop and recording on audacity.
But the recording im getting is very quiet, distorted, no bass aswel.
WHen i record the input from the N4 (using the n4 as nothin more than a mixer) and use windows media player instead of serato dj intro, the recording quality is perfect. However when i record form the n4 input whilst playing through serato (which uses teh n4 usb as its output) the sound quality is again quiet, distorted and with no bass.
Its as if the booth output on the n4 doesnt give out good enough sound signal for the computer.
I hope this clears things up?
Post by steve » Tue Sep 04, 2012 3:36 pm
harveylax wrote:WHen i record the input from the N4 (using the n4 as nothin more than a mixer) and use windows media player instead of serato dj intro, the recording quality is perfect.
What's the diagram for that?
WMP ==> ??? ==> Numark N4 controller ==> ??? ==> Audacity
What are the "???"
Post by kozikowski » Tue Sep 04, 2012 10:07 pm
I think that's what I'm trying to understand. So the show is already going back and forth between the computer and the N4 with Serato managing the pathways and directions. I think you ran out of sound pathways. There's no way to catch the sound that's on its way out to the speakers without a second computer and capture system.
The minute you try to reverse the outgoing speaker feed as an incoming signal for Audacity, it interferes with Serato because that's the pathway it uses to bring the N4 back into the computer. I think you're recording two or more pathways by accident and that will give you serious distortions, funny bass, and odd cancellation effects.
Unless somebody contradicts me, you either can't do this with one computer, or there may be special provision for recording your show. I can't believe you're the first person to want to record their Serato tracks.
But that's not an Audacity problem. Unlike Serato, Audacity does not create or manage audio pathways. It can only use that Windows provides and right now, Windows is sharing with Serato.
DVDdoug
Forum Crew
Post by DVDdoug » Tue Sep 04, 2012 11:25 pm
Have you plugged an amplifier into the booth output to see what it sounds like? (If you don't have an amp handy, you can try your computer speakers, which have an amp built-in.)
Your Line to USB interface is going to want a "full-scale" line-level input, which means not volume-controlled, or the volume controls near the maximum. (Real-world analog levels vary a lot, so full-volume might overload/distort the ADC, but you do need a signal that's "loud" when connected to an amp or to headphones.)
P.S.
You can also try connect the line-outputs from a CD or DVD player to your line-to-USB interface to check the recording capability.
harveylax
Post by harveylax » Wed Sep 05, 2012 12:31 pm
HI again,
Firstly Massive thanks to evryone so far for helping me out, i massively appreciate it. I've posted on both serato and N4 forums and ive not had any feedback. I can't believe your the only free software IM suing and the only people to provide customer service. So thanks so much :D .
the windows media p[layer diagram is eexaclt ythe same except WMP replaces serato, so its ;
WMP == USB==> N4 ===auxilliary booth output RCA to usb==> laptop /audacity recoridng...as far as I can tell thats essentially the same thing as the set up with serato. I understand that recording the N$ input would be dodgy, but recording from a seperate USB input coming out of thge booth output on the n4 should work so ive been told.
I'll try the suggestion about recording a line out to usb from my amp as that will verify if the problem is with the computer.
I also know im not the first person whos tried to record their mixes from serato dj intro, theres a lot of threads requesting it, but i have honestly read them all followed all teh possible solutions so far and still can't get the quality decent, I've improved it using some measures but its still way off what i know is possible.
Thanks again guys, your like some kind of mystical help warriors!
Post by steve » Wed Sep 05, 2012 12:50 pm
harveylax wrote:your the only free software IM suing
I hope that's a typo :D
harveylax wrote:WMP == USB==> N4 ===auxilliary booth output RCA to usb==> laptop /audacity recoridng
What are the "USB" connections? Are they built into the N4 or are they standalone USB sound cards?
harveylax
Post by harveylax » Thu Sep 06, 2012 9:06 am
HI again,
haha yes it was a typo ;)
The usb input is built the booth output is a line output which is what I'm trying to record from using a 2 x RCA phone cable to USB converter.
The cable is USB 2.0 and mylaptop is has both 3.0 and 2.0 usb ports, I've tried both but they produce the same difficulties.
Hope this helps and thanks again.
Post by steve » Thu Sep 06, 2012 11:36 am
I'm not familiar with Serato or the N4 so you will need to help me out here.
If you connect a USB output from your computer to the USB input of the N4, and connect the booth output from the N4 to an amp/powered speakers, can you then play any application (example, WMP. Serato, Audacity, VLC or any other media player) out through the speakers via the N4?
