Creating space for reverb within a track
DooWahDiddy
Post by DooWahDiddy » Wed Aug 29, 2012 7:07 pm
Hi there,
I searched for an answer to this question but wasn't sure what keywords to use. Basically I'm making a multi-track recording, and one snippet of vocals (that has its own track) is only 3 or 4 seconds long. I want to apply a massive amount of reverb to it, but when I do that, the sound waves flatten out so much that they exceed the boundaries of the track, if that makes sense. So the end of the reverb keeps getting cut off. Is there any way to tell Audacity I want to create more room at the end of the track? Not the end of the SONG, but the end of this 3-4 second track.
Thanks for your help!
Re: Creating space for reverb within a track
Post by steve » Wed Aug 29, 2012 7:18 pm
Which reverb effect are you using?
If you are using GVerb you will need to add enough silence at the end of the voice to allow for the reverb.
To do that,
  • select the voice track then press the "K" key to move the cursor to the end of the track
  • "Generate menu > Silence" to generate some silence at the end of the track.
You will now have something like this:
added silence.png (9.86 KiB) Viewed 1055 times
Then you can apply the GVerb effect:
DooWahDiddy
Post by DooWahDiddy » Thu Aug 30, 2012 1:13 pm
Ahhhhh, "add SILENCE", that's what I couldn't figure out. Thank you so much!
