Saving usb output from a fender mustang-I amp [linux]
Please state:
Please state:
Stratovarius
Hi,
I posted in alt.guitar.amps.fender but I think that that group is very thin and slow. I'm trying to use Audacity-2.0.0-73.1 on OpenSuse-12.1 (and soon 12.2) to record amplifier usb output from a Fender Mustang-I . Has anyone done this? What do I need to do exactly?
Thanks a meg
Thanks a meg
Re: Saving usb output from a fender mustang-I amp [linux]
From a quick look at their web site:
http://www.fender.com/en-GB/products/mu ... utal-metal
If you plug the USB into your computer, does it show up as an audio device?Mustang includes USB connectivity for high-quality, low-latency audio output,
Stratovarius
Yes, thanks for the quick response!!!
Shows up as the 4th i.e. 3, I have only crappy little onboard cards though
pactl list sources short
0 alsa_output.pci-0000_05_00.1.hdmi-stereo.monitor
module-alsa-card.c s16le 2ch 44100Hz SUSPENDED
1 alsa_output.pci-0000_00_14.2.analog-stereo.monitor
2 alsa_input.pci-0000_00_14.2.analog-stereo
3 alsa_input.usb-FMIC_Mustang_Amplifier_AF98FF303235423157216139-02-Amplifier.analog-stereo
Handicap: new to sound, new to Audacity, no linux guru either
If you're lucky, all that you will need to do is the plug in the USB, wait for it to be detected by the OS, then open Audacity and select the USB option as the recording input using the Device Toolbar. http://manual.audacityteam.org/man/Device_Toolbar
Stratovarius
Thank you. Got it going but while the Audacity recording mic volume level is all the way and frozen there, the actual recording sensitivity is low. I have to turn the amp quite a ways up to get a decent wave amplitude.steve wrote:If you're lucky...
Using OpenSUSE-12.1/64 & KDE
Stratovarius
while waiting for my earlier reply to clear...steve wrote:If you're lucky
I found a way to get around the recording level problem but it gets distorted sound cause I have to raise volume and gain on the amp all the way while turning master volume down, it's only good as a temporary fix
Then, after recording a piece I'd want to record a new track either all by itself while listening to the first one and subsequently mix them together and/or dub unto the first one. In any event as soon as I press the record button again I get this:
Latency Correction setting has caused the recorded audio to be hidden before zero.
Audacity has brought it back to start at zero.
You may have to use the Time Shift Tool (<---> or F5) to drag the track to the right place.
twice if its stereo.
- Quality Assurance
This happens if the recording starts and stalls or fails.Stratovarius wrote:Then, after recording a piece I'd want to record a new track either all by itself while listening to the first one and subsequently mix them together and/or dub unto the first one. In any event as soon as I press the record button again I get this:
Assuming you didn't enable Transport > Sound Activated Recording, it probably means your sound device cannot cope with Transport > Software Playthrough being enabled while playing an existing track as well as recording. Or maybe it cannot play and record simultaneously at all?
Stratovarius
OpenSuse-12.2 & audacity-2.0.0-2.1.2
I just had a bit of time to revisit this issue albeit to no avail.
The volume is too low, I had to turn the amp and guitar volumes all the way up to get a crappy little trace (using the headphone so as not to blow the radiator). The sound is also staccato-like, full of crackling, & apparently at double speed. Useless.
Here's a short 15 second sample
http://www.trixtar.org/tinkerings/grab- ... -short.mp3
Has anyone on the list actually tried this amp with audacity _Successfully_ ?
Yes there have been a couple of other users that have eventually got that amp to work with Audacity (users only generally only write to the forum when they have problems and not when everything is working fine). I don't recall any of those users being on Linux.Stratovarius wrote:Has anyone on the list actually tried this amp with audacity _Successfully_ ?
The major problem there is "skipping" http://manual.audacityteam.org/man/FAQ: ... ting#skipsStratovarius wrote:Here's a short 15 second sample
There is another OpenSUSE user that we are currently trying to help on the forum that also has major problems with skipping while using a USB audio device.
The first thing is - don't use a USB hub, the device must be connected directly to the USB port.
Next thing - try a different USB port.
I'm starting to think that there may be some underlying problem with high speed USB on OpenSUSE 12, so I've done a quick search on Google and there are numerous hits for "Slow USB on OpenSUSE 12".
One suggestion from Google is to ensure that you are using the 3.1.10 kernel.
Another suggestion is that the system may be loading USB 1 drivers rather than USB 2. (see here: http://tr.opensuse.org/SDB:USB_2.0)
Your amp is probably USB1 compatible so is unlikely to trigger the "device is busy" error, but may be related to poor USB performance.
I also found this bug report that relates to USB and Gnome Volume Control Applet
https://bugzilla.novell.com/show_bug.cgi?id=591142
and this bug related to USB speed:
https://bugzilla.novell.com/show_bug.cgi?id=710133
Stratovarius
oh sheeeeeesh!
I never saw this one, my apologies. Appreciate you going to all the trouble of looking up the bugs
I will try this again some day but am for now bogged down with other issues with this type of guitar amp (bought another one so I now have 2) and another one related to Audacity that I will post under another heading.
