vinyl ripping setup help!
Help for Audacity on macOS.
jamieharden
Post by jamieharden » Wed Aug 22, 2012 7:58 pm
hey, so I want to rip some of my vinyls like many others...anyway i have a few questions...
as it stands i have my technics hooked up with a quality cartridge but i am getting confused with some of the equipment i may need.
as it stands I have a:
sony DA3ES receiver that has phono inputs but i dont know if this is good enough to record flac...also do I need an external soundcard or can I just hook it up directly to my macbook pro's audio in? i do have a traktor audio 2 but i dont know how i would even use that...please help!
Re: vinyl ripping setup help!
Post by kozikowski » Wed Aug 22, 2012 8:23 pm
Your entertainment amplifier has Phono-In and Tape-Out, right? Connect the turntable to the Phono-In (remember to connect that little black grounding wire). Connect the amplifier Tape-Out to the Mac with one of these.
http://kozco.com/tech/audacity/pix/RCAMiniStereo.jpg
It's the connection with the thin circle and two black arrows.
http://www.kozco.com/tech/audacity/pix/MacLineIn.jpg
That appears as Built-In-Input, Stereo in the Audacity device toolbar.
http://manual.audacityteam.org/o/man/de ... olbar.html
My sister in Schenectaby has an amplifier where the Tape-Out is broken. In that case, I connected the Line-Out.
