Exponential Wind-downs for synths?
Re: Exponential Wind-downs for synths?
Post by steve » Sat Aug 25, 2012 9:19 am
Try this:
Code: Select all
(setq start-frequency 10) ; initial frequency in kHz
(setq end-frequency 1) ; final frequency in kHz
(let* ((ny (/ *sound-srate* 2))
       (f1 (min (* start-frequency 1000) ny))
       (f2 (min (* end-frequency 1000) ny)))
  (lp (lp s (pwlv f1 1 f2))(pwlv f1 1 f2)))
The start and end frequencies must be less than half of the track sample rate.
Thewoog34
Post by Thewoog34 » Sat Aug 25, 2012 7:19 pm
Perfect, now I have to just fool around with it until it sounds right.
I have this little piece of code here that converts any waveform into non-aliased triangle (a little mis-shapen though), I'll try and fix it up and create one for saw and square.
(mult 2.0 (sum (snd-abs s) -0.5))
Thewoog34
Post by Thewoog34 » Mon Aug 27, 2012 4:56 am
sites.google.com/site/nmoakman/test/fsweep.dll
http://www.youtube.com/watch?v=EXCQrnr9 ... ture=g-u-u
Check out this little plugin that Nick Oakman made. He owns the Youtube channels alarmsynthsrus and guitarguy19852.
