Lame Converter MP3
thor21344
Re: Lame Converter MP3
Post by thor21344 » Wed Aug 22, 2012 4:38 pm
Sven, Audio Converter does not work in conjunction with Audacity. Audacity SAVES the audio file as an .AU file. then you load the .AU file in to the converter IF it will accept the .AU file and then convert it.
If you download and then use LAME you will be able to export the file from Audacity to MP3 or WAV files in ONE process.
I believe that you have misunderstood about Audio Converter and LAME and Audacity. They are actually 3 totaly different programs. LAME will work with Audacity for exporting files. Audio Converter will convert certian type of files, but the file has to already been saved. Again Audacity will onl SAVE .AU files. If Audio Converter will read the .AU file then you can convert it but only after it has been saved.
Hope this helps
Marty
