Adjusting pitch
Tim T
Adjusting pitch
Post by Tim T » Sat Aug 18, 2012 11:56 am
I want to standardize the pitch of some pre recorded music. Can I adjust the pitch for playback? How? Thank you for your time. Tim.
PGA
Re: Adjusting pitch
Post by PGA » Sat Aug 18, 2012 2:17 pm
Import the sound file, select it all and Effect > Change Pitch.
