As I timeshifted the block back to the left, just before I got the alignment with position zero on the timeline, I got the warning window pop-up advising that Audacity had stopped responding and that Windows was searching for a solution. I let that run for a while and then cancelled. I then double-clicked the .aup file to re-lauch it and was given the "Audacity can recover..." window. I selected the option to Recover Project. It seems to have recovered correctly but along the way I was prompted to do Help > Show Log. The text from the log is included below:
Code: Select all
14:15:34: Audacity 2.0.1
14:15:35: Error: Couldn't find symbol 'MainPanelFunc' in a dynamic library (error 127: the specified procedure could not be found.)
14:15:35: Trying to load FFmpeg libraries...
14:15:35: mLibAVFormatPath ('C:Program Files (x86)FFmpeg for Audacityavformat-52.dll') is not empty. Loading from it.
14:15:35: Looking up PATH environment variable...
14:15:35: PATH = 'C:Windowssystem32;C:Windows;C:Windowssystem32wbem;C:WindowsSystem32WindowsPowerShellv1.0;C:Program Files (x86)Common FilesRoxio SharedDLLShared;C:Program Files (x86)Common FilesRoxio Shared13.0DLLShared;C:Program Files (x86)Common FilesRoxio SharedDLLShared;C:Program Files (x86)Common FilesRoxio SharedDLLShared;C:Program Files (x86)Common FilesRoxio Shared13.0DLLShared'
14:15:35: Checking that 'C:Program Files (x86)FFmpeg for Audacity' is in PATH...
14:15:35: Warning: FFmpeg directory is not in PATH.
14:15:35: Temporarily appending ';C:Program Files (x86)FFmpeg for Audacity' to PATH...
14:15:35: Checking for monolithic avformat from 'C:Program Files (x86)FFmpeg for Audacityavformat-52.dll'.
14:15:35: Error: Couldn't find symbol 'avutil_version' in a dynamic library (error 127: the specified procedure could not be found.)
14:15:35: avformat not monolithic
14:15:35: Loading avutil from 'C:Program Files (x86)FFmpeg for Audacityavutil-50.dll'.
14:15:35: Loading avcodec from 'C:Program Files (x86)FFmpeg for Audacityavcodec-52.dll'.
14:15:35: Loading avformat from 'C:Program Files (x86)FFmpeg for Audacityavformat-52.dll'.
14:15:35: Returning PATH to previous setting...
14:15:35: Actual avutil path C:Program Files (x86)FFmpeg for Audacityavutil-50.dll
14:15:35: Actual avcodec path C:Program Files (x86)FFmpeg for Audacityavcodec-52.dll
14:15:35: Actual avformat path C:Program Files (x86)FFmpeg for Audacityavformat-52.dll
14:15:35: Importing symbols...
14:15:35: All symbols loaded successfully. Initializing the library.
14:15:35: Retrieving FFmpeg library version numbers:
14:15:35: AVCodec version 0x342000 - 52.32.0 (built against 0x344802 - 52.72.2)
14:15:35: AVFormat version 0x342400 - 52.36.0 (built against 0x344002 - 52.64.2)
14:15:35: AVUtil version 0x320300 - 50.3.0 (built against 0x320f01 - 50.15.1)
14:15:35: FFmpeg libraries loaded successfully.
14:15:49: Warning: Orphan block file: 'J:My DataMy PlaypenSoundSyncLockTest_datae00d00e0000056.au'
14:15:49: Warning: Orphan block file: 'J:My DataMy PlaypenSoundSyncLockTest_datae00d00e00001c3.au'
14:15:49: Warning: Orphan block file: 'J:My DataMy PlaypenSoundSyncLockTest_datae00d00e00001c9.au'
14:15:49: Warning: Orphan block file: 'J:My DataMy PlaypenSoundSyncLockTest_datae00d00e0000206.au'
14:15:49: Warning: Orphan block file: 'J:My DataMy PlaypenSoundSyncLockTest_datae00d00e00003f9.au'
14:15:49: Warning: Orphan block file: 'J:My DataMy PlaypenSoundSyncLockTest_datae00d00e000049e.au'
14:15:49: Warning: Orphan block file: 'J:My DataMy PlaypenSoundSyncLockTest_datae00d00e0000723.au'
14:15:49: Warning: Orphan block file: 'J:My DataMy PlaypenSoundSyncLockTest_datae00d00e000090b.au'
14:15:49: Warning: Orphan block file: 'J:My DataMy PlaypenSoundSyncLockTest_datae00d00e00009d0.au'
14:15:49: Warning: Orphan block file: 'J:My DataMy PlaypenSoundSyncLockTest_datae00d00e0000b1f.au'
14:15:49: Warning: Orphan block file: 'J:My DataMy PlaypenSoundSyncLockTest_datae00d00e0000bc5.au'
14:15:49: Warning: Orphan block file: 'J:My DataMy PlaypenSoundSyncLockTest_datae00d00e0000bfd.au'
14:15:49: Warning: Orphan block file: 'J:My DataMy PlaypenSoundSyncLockTest_datae00d00e0000c57.au'
14:15:49: Warning: Orphan block file: 'J:My DataMy PlaypenSoundSyncLockTest_datae00d00e0000cf9.au'
14:15:49: Warning: Orphan block file: 'J:My DataMy PlaypenSoundSyncLockTest_datae00d00e0000e8f.au'
14:15:49: Warning: Orphan block file: 'J:My DataMy PlaypenSoundSyncLockTest_datae00d00e0000ebe.au'
14:15:49: Warning: Orphan block file: 'J:My DataMy PlaypenSoundSyncLockTest_datae00d00e0000f66.au'
14:15:49: Warning: Orphan block file: 'J:My DataMy PlaypenSoundSyncLockTest_datae00d00e0000f8d.au'
14:15:49: Warning: Orphan block file: 'J:My DataMy PlaypenSoundSyncLockTest_datae00d00e0000fc9.au'
14:15:49: Warning: Orphan block file: 'J:My DataMy PlaypenSoundSyncLockTest_datae00d00e0000fdd.au'
14:15:49: Warning: Project check ignored orphan block file(s). They will be deleted when project is saved.
14:15:49: Warning: Project check found file inconsistencies inspecting the loaded project data.
I still haven't worked out a sequence of steps that will, repeatably, set up and use SyncLock. If I'm going to get crashes every time I try, I am not going to make any headway on this. When it works, I can see the benefit to my workflow; but I have to be able to repeat the desired effect without the undesired one!
regards,
Peter
