changing amplification default value
Help for Audacity on macOS.
maximoff
Post by maximoff » Sat Aug 11, 2012 4:57 am
Hi:
In the "Amplify" effect, the amplification is set by default to 10.7 dB. Is there a way to change it (not on a one time basis; actually change the default value)?
Thanks,
EM
Re: changing amplification default value
Post by Gale Andrews » Sat Aug 11, 2012 6:28 am
maximoff wrote:Hi:
Amplify is set by default to so as to amplify to the maximum amount possible without distortion. So if you use Amplify on a very quiet track it will offer you a much higher amplification.
To set the volume of a track to a pre-defined level irrespective of what level it is now, use Effect > Normalize:
http://manual.audacityteam.org/o/man/normalize.html .
maximoff
Post by maximoff » Sat Aug 11, 2012 6:48 am
Thanks a lot, Gale.
EM
Gale Andrews wrote:
maximoff wrote:Hi:
