Voice Recording Quality
jhoge123
Post by jhoge123 » Tue Aug 07, 2012 8:57 pm
Hi,
I'm recording voice over for youtube videos, and want to try to improve the quality without spending a fortune. I have a decent XLR cartioid mic, a TUBEPre preamp and record using a Porta-Booth to block out random room noise. I still have some white noise in my recordings
Noise.wav
(280.04 KiB) Downloaded 143 times
Here's the Frequency Analysis
I realize fighting noise is a never-ending battle, but what is the next step? What is a reasonable goal?
Re: Voice Recording Quality
Post by kozikowski » Tue Aug 07, 2012 10:48 pm
Which is? We thrive on details.
Your test clip is equal parts gentle rain-in-the-trees white noise and a refrigerator compressor somewhere in the apartment. Maybe computer fan noise.
This is where we find you've been recording with the microphone on top of the computer and it's picking up fan rumble. You are using a shock mount, right?
Now post a short clip of your normal performing voice with about a second of silence on both ends. No Processing. Raw capture.
http://forum.audacityteam.org/viewtopic ... 49&t=64936
You can get roughly twice as much work time as your last file in that configuration.
NoiseAmplified.wav
(280.04 KiB) Downloaded 112 times
PGA
Post by PGA » Wed Aug 08, 2012 5:53 am
Re-run your spectrum plot with Size at maximum and Axis set to Log Frequency then stretch the window across the width of your monitor. You'll see something like this:
Spectrum Plot at Size=1638, Axis=Log frequency from your file
You can see that you have several very large, sharp spikes. You might try using the notch filter on each of those spikes to see if one or more of them is the primary culprit. Remember that the notch filter will remove the selected frequency from ALL of the recording, so there's no guarantees. I have used it successfully to remove the whine of a heavy duty water pump from location recordings made at a water mill. I was pointed in that direction by Steve on this forum.
jhoge123
Post by jhoge123 » Wed Aug 08, 2012 4:00 pm
I have a MXL 2001 mic. It's inside a Porta-Booth, and resting on the Auralex pyramids, which isn't quite a shock mount but probably prevents vibration propagating up from the desk.
I've recorded a second clip with voice and noise. When I do the frequency analysis of the noise portion I do see peaks at about 20hz and a narrow one at 60, which I guess is electrical. Peaks are about -48db.
What is a reasonable expectation for noise in a home studio for voice over?
Noise2.wav
(818.04 KiB) Downloaded 116 times
I was considering upgrading to a USB mic to avoid the preamp and reduce the potential for electrical interference. Anybody had any luck with them?
Post by kozikowski » Wed Aug 08, 2012 5:02 pm
Do you have a grandfather clock in the room? Anything that could cause that rhythmic ticking sound? Most of the problem is still room noise. You sound like you're recording in your mom's kitchen with the echoes and all that stuff going on in the background behind you.
http://www.kozco.com/tech/audacity/clips/EchoSample.mp3
Soundproofing behind the microphone is half the fun. Now you have to soundproof the walls where the microphone points -- you and behind you. We have people who record in a closet with blankets and quilts lining the walls to get rid of room reverberation.
http://www.kozco.com/pictures/boothFini ... op-mic.jpg
Shifting to a high quality USB microphone is going to make the ticking and background sounds much better and clearer.
I applied gentle noise removal starting at 3 seconds. Turn it up to listen. There's no tools to get rid of echo.
Noise2-w-amplify-removal.wav
(818.04 KiB) Downloaded 121 times
Trebor
Post by Trebor » Sat Aug 11, 2012 11:34 pm
You can squelch long silences down to true silence with a noise gate ...
Noise2, before-after NR then noise gate.mp3
(611.43 KiB) Downloaded 235 times
oh here's a resized version of the mic photo above ...
