Automated detach for silence works but not export
Help for Audacity on macOS.
Silence07
Post by Silence07 » Mon Aug 06, 2012 8:14 pm
Hello
Iam using 2.0.1 on a MBP and recording works fine so far, dividing tracks by using" detach for silence" creates bright and darker areas but how can I export the single files from that??
(Tracks are recorded from minidisc and MD creates a 3 second silence between each track (recorded optical) )
-> On Multiple exports he tells me that this does not work? By I can I convert the selection or label track or what needed to export the found sections into single files? E.g. Paste text to new label creates onlz one long file... :?:
Re: Automated detach for silence works but not export
Post by Gale Andrews » Tue Aug 07, 2012 12:06 am
Use Analyze > Silence Finder instead of "Detach at Silences". Silence Finder will label the silences, then you can use Export Multiple.
See http://manual.audacityteam.org/o/man/sp ... racks.html .
Silence07
Post by Silence07 » Tue Aug 07, 2012 5:21 am
Hello
thanks for the feedback but under Analyze I only have:
- Contrast
- Plot Spectrum
- Find clipping
Is a plugin missing?
Post by Gale Andrews » Thu Aug 09, 2012 7:39 am
Silence07 wrote:under Analyze I only have:
- Contrast
- Plot Spectrum
- Find clipping
The plug-ins you are missing are "Nyquist" plug-ins. Do you get a warning when you launch Audacity that Nyquist Plug-ins will not be available?
If not, click Audacity > Preferences, then Effects on the left, put a checkmark by "Nyquist", click OK then restart Audacity.
