MP3 export message
ecpix3
MP3 export message
Post by ecpix3 » Tue Sep 18, 2007 1:25 am
Ok, I'm really new at using Audacity and after a barrage of lame_enc.dll errors and a few hours of technical support, I'm nearly bald at this point! I've gotten rid of most of the errors now. The latest of hurdles comes when I am trying to export as a MP3. I click export as MP3, save and I get "unable to open target file for writing" message. Anyone have any suggestions what this could be? These are sound clips I'm downloading onto CD-R music recordable discs. It's a new disc, full, plenty of space... I'd really appreciate the help! I need to be able to record sound on my hand-held digital recorders, upload it to my computer, clarify it, separate it and download pieces of it and give a copy of pieces of it to customers as needed. Sounds simple enough but judging by the bald spots, it's more complicated than I bargained for...
Thanks to anyone willing to help us out!!!
ECPI
Re: MP3 export message
Post by kozikowski » Tue Sep 18, 2007 4:56 am
<<<a few hours of technical support>>>
You must be on a PC, right?
<<<I've gotten rid of most of the errors now.>>>
I'm more than passably interested in what those errors were. Most people's machines don't take hours of technical support. You may have an unstable machine causing other problems.
<<<trying to export as a MP3. >>>
You can export as a Windows WAV file right now, right? And it works OK after you do that? I'm after this answer for a very specific reason.
Did you have a lot of trouble downloading and decompressing the LAME libraries? I don't remember where they go on a PC. Where did it want you to put them? What did the instructions say?
mudeth
Post by mudeth » Tue Sep 18, 2007 12:57 pm
Hi, rpand4.. I hope you aren't trying to save the file directly onto the CD. Are you trying to do that? Also, I agree with Koz, audacity doesn't install too many things that affect your system, so I don't know how it can cause your OS to go down.
alatham
Post by alatham » Tue Sep 18, 2007 1:44 pm
mudeth is right, you cannot save directly to a CD. Save the files to your hard disc and burn them all later if you need to.
ecpix3
Post by ecpix3 » Thu Sep 20, 2007 10:40 pm
Ooh hoo! I have found a round-about way of getting it to burn! The ONLY way I can get it to burn is through my computer, copy the files to a disc feature. It will not export as WAV or MP3. ????
