Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
mm170930
Post
by mm170930 » Fri Aug 03, 2012 3:04 pm
I have downloaded Audacity onto my laptop and am attempting to edit my recordings.
Basically, what I am trying to do is delete a few seconds here or there that are unnecessary. Also, I want to generate a silence between two sections which I did not pause long enough.
Now here is my problem, Where I am clicking in audacity sort of isn't being registered.
You can see in my screencap I am trying to click the little space between the two sounds, But it is actually clicking at the end of my first sound. I can't figure out how to make it let me click where I want
can anyone help me?
ragnar.jensen
Post
by ragnar.jensen » Fri Aug 03, 2012 6:06 pm
Clear the "Snap To" checkbox.
- Snap to
- snapto.png (73.34 KiB) Viewed 549 times
Ragnar
mm170930
Post
by mm170930 » Sat Aug 04, 2012 3:54 pm
ragnar.jensen wrote:Clear the "Snap To" checkbox.
Ragnar
Thank you so much! I'm new to this program.
