16 Bit to 8 bit help
tdbq
Post by tdbq » Thu Aug 02, 2012 3:55 pm
Hello,
I am new to this so please bear with me. I have windows 7 pro and just downloaded audacity. I uploaded a .wav file that needs to be saves in 8-bit, 8khz, mono. The program defaults it to 32-bit, 8khz, mono. I see I can change it to 16 bit but can't find an option to save it as 8 bit. Has to be 8 bit for my phone system - any assistance is appreciated.
ragnar.jensen
Re: 16 Bit to 8 bit help
Post by ragnar.jensen » Thu Aug 02, 2012 5:45 pm
File -> Export...
In the Export File dialog select "Other uncompressed files" as the file format.
Click the Options... button in the same dialog.
Select WAV and 8-bit in the Options dialog.
Specify Uncompressed Options dialog
Ragnar
tdbq
Post by tdbq » Thu Aug 02, 2012 8:56 pm
THANK YOU VERY MUCH!!
