restore defaut settings for noise removal
justinrpg
Banned
Post by justinrpg » Sat Jul 28, 2012 3:17 pm
I borked up all the sliders for the noise removal effect in Audacity and now it doesn't matter what file I load or how many times I close Audacity, the sliders are borked!!! is there any way to return them to default??? noise removal won't work now!!!
waxcylinder
Re: restore defaut settings for noise removal
Post by waxcylinder » Sat Jul 28, 2012 3:34 pm
This page in the manual will show you the default settings (our policy in the manual is to show default settings for effects, analyzers and generators) :
http://manual.audacityteam.org/help/man ... moval.html
There is currently no mechanism in Audacity to restore the defaults - but curiuosly the QA elves have recently been discussing either the possibility of a marker in the effect or a restore defaults button. See this thread: http://forum.audacityteam.org/viewtopic ... 20&t=66964
You can your 2c. worth there or just addd a vote in a post if you wish.
yugioh47
Post by yugioh47 » Fri Apr 03, 2015 5:02 pm
hi there, i'av got the same problem audacity. the settings that i've setup on audacity plugin's go back into default. and only when i do the batch file process that is doesn't load the settings that i've saved. when i click close and can't press apply either with won't load the settings i've set. can this please be fixed?
also i can not go to the manual it's forbidding me.
thank you
Post by steve » Fri Apr 03, 2015 5:48 pm
yugioh47 wrote:hi there, i'av got the same problem audacity. the settings that i've setup on audacity plugin's go back into default. and only when i do the batch file process that is doesn't load the settings that i've saved. when i click close and can't press apply either with won't load the settings i've set. can this please be fixed?
I presume that you are referring to the same issue that I replied to here: http://forum.audacityteam.org/viewtopic ... 20#p271920
yugioh47 wrote: also i can not go to the manual it's forbidding me.
If you mean the on-line manual (http://manual.audacityteam.org/o/) then you will need to take that up with the IT administrator responsible for your Internet access.
If you mean the manual included in the Windows installer, then you may need to log in with the same account as was used when installing Audacity.
I'm locking this topic as it is over 3 years old. If you require further assistance, please start a new topic.
