Strange problem
Pobinr
Strange problem
Post by Pobinr » Tue Jul 24, 2012 11:43 pm
Hi
I've used Audacity with no probs in the past.
I have windows 7 & 64 bit processor.
I've started getting a problem that's so weird it would be hard to put into words !
So it's best illustrated with this video http://www.youtube.com/watch?v=w65iNCP52bw
I uninstalled earlier version & downloaded 2.0.1 to see if fixed it but made no difference.
Overdub is on
I use a Line 6 UX2 with POD farm.
Any ideas?
Re: Strange problem
Post by steve » Wed Jul 25, 2012 12:01 am
That certainly shows the problem.
Check all of the items listed in "Why is my new track out of sync with the previous ones, or sounds crackly or at wrong pitch"
