I hooked up a Numark USB turntable to my laptop. I am using Audacity to listen and record. I have it monitoring the input. The output as my built in output and the input as the usb turntable. When the record plays I hear nothing but it shows it playing. The only time I can hear the record is if I record it and then play it back.
How do I hear it while I am not recording and also while recording.
Usb Turntable no sound.
Re: Usb Turntable no sound.
Thanks for the reply. I am using a Mac though.
Topic moved to the Mac OS X forum.
Got it to work finally!
