Audacity 2,0,1 on Mac Snow Leopard 10.6.8
wwayneottinger
The old version of Audacity quit working (recording) so I removed in and installed 2.0.1, Still will not record, set it up for external usb mic, which shows OK.
- Quality Assurance
Re: Audacity 2,0,1 on Mac Snow Leopard 10.6.8
If you attached the mic after launching Audacity, use Transport > Rescan Audio Devices.
Also see:
http://wiki.audacityteam.org/wiki/User: ... ut_devices .
Also see:
wwayneottinger
I installed the mic before I opened Audacity, the mic shows OK in Audacity.
I also copied all the dmg files and pasted them in a new folder I made for Audacity in the Applications folder.
It opens fine, it just will not record.
Where do I find "Transport" to rescan the mic's?
- Quality Assurance
OK, if you mean you copied all the files that were in the dmg.wwayneottinger wrote:I installed the mic before I opened Audacity, the mic shows OK in Audacity.
In the Audacity menu bar which will be at the top of the OS X window when you are in the Audacity program.wwayneottinger wrote:Where do I find "Transport" to rescan the mic's?
Is there "error opening sound device" when you select the USB mic as Input Device in Audacity Device Toolbar? Or do you just record silence?
The mic will probably be called USB Audio CODEC. This is Device Toolbar:
