I'm a reasonable dab hand at doing Bartley Gorman (the inspiration for Tom Hardy's pre-processing Bane voice in TDKR, see here). I can get about 90% of the way with the old tin-can-with-nail-holes-in-the-bottom trick.
But there's a loudspeaker/bullhorn/crappy speaker quality to Bane in TDKR that I'm having a hard time nailing down. What would you tinker with in Audacity to try to get it right?
Ubuntu version, if it matters.
Effects to sound like Bane in The Dark Knight Rises?
Re: Effects to sound like Bane in The Dark Knight Rises?
I can only guess at what you have so far, but try applying this code in the Nyquist Prompt effect:
Code: Select all
(nrev
(mult 0.4 (sum
(eq-band s 5000 16 2)
(eq-band s 100 16 1)))
0.01 0.2)
Thanks, Steve.
So far I have nothing at all – I've been seeing how far I can get with my own voice and some practical effects (hence the tin can with holes in it). I haven't played with audio software since Cool Edit Pro was in its infancy, but I know Audacity is the solution of choice for freeware recording these days.
When you've got something recorded you're welcome to post a short sample and perhaps someone will have suggestions for how to improve it.WannaBane wrote: So far I have nothing at all
I see what you mean about "tin can"/ "megaphone" ... https://www.youtube.com/watch?v=GokKUqLcvD8#t=90s
It's very sibilant, re-ess* maybe ? , [ * opposite of de-ess ]
