brewsty39
Post
by brewsty39 » Tue Jul 24, 2012 11:49 am
Hello Gang.
I've got myself a
Lenovo G560E with Audacity downloaded, a pair of
Pioneer CDJ400s, and a
Numark M1 mixer. My question to you folks out there is how the devil can I get recording? I've had a good read through the forums and can't find much information, especially given I'm using an entry level mixer. I've got RCAs, and was wondering if I should be investing in a Behringer UCA202 after reading up on the forums here. Then again, it's only guesswork.
Can anyone enlighten me, or send me in the right direction?
Thanks in advance,
Nani
- Site Admin
Post
by steve » Tue Jul 24, 2012 5:28 pm
I'd expect the UCA 202 to work well with your set-up though you'll need to be careful not to push the output level from your mixer too high.
Your set-up will be similar to this
http://manual.audacityteam.org/manual/h ... mixer.html (see the links for more details).
brewsty39
Post
by brewsty39 » Wed Jul 25, 2012 8:01 am
brewsty39
Post
by brewsty39 » Thu Jul 26, 2012 1:49 pm
Hello again, sorry to be such a loser, but I'm still struggling.
I've got by Behringer UCA202 hooked up through my laptop, and connected with the RCA cables. What's going wrong? What do I have to do now to start recording through Audacity...
Confused + embarrased ....
brewsty39
Post
by brewsty39 » Thu Jul 26, 2012 2:25 pm
I'm still stuck my friends, I've got my RCAs into the Input of the UCA202, then its plugged via USB into my laptop - and I think the final piece of the puzzle is to use the Headphone Jack in tha UCA202 to plug back into my Amp + Speaker set-up via RCAs with a converter.
Is that correct, sound about right?
HELP!
Thanks folks
- Site Admin
Post
by steve » Thu Jul 26, 2012 3:17 pm
Connect the mixer to the RCA inputs of the UCA 202.
Connect the outputs of the UCA 202 to your amp.
Connect the USB from the UCA 202 to your laptop.
Open Audacity - if it's already opn, close and restart it.
Set both the input and output settings in the Device Toolbar to the USB option:
http://manual.audacityteam.org/man/Device_Toolbar
brewsty39
Post
by brewsty39 » Thu Jul 26, 2012 4:01 pm
Thank you both for your wisdom!
I have Audio, and Audacity works fine. My issue now is that the audio quality on the other end isn't top drawer, and it's too bassy.
You've done enough though so will scout the forums for more advice.
Thank you loads
Post
by kozikowski » Thu Jul 26, 2012 4:29 pm
Wait. Other end of what? Koz
brewsty39
Post
by brewsty39 » Thu Jul 26, 2012 5:17 pm
Sorry I just meant after I record it on Audacity, the audio playback is all fuzzy and horrible
cheers
