ringmod.ny help?
Help for Audacity on macOS.
MissingNO123
ringmod.ny help?
Post by MissingNO123 » Mon Jul 23, 2012 8:45 pm
I'm trying to make the Dalek and Cyberman voices heard on Doctor Who but so far I've found nothing.
DETAILS
Audacity for Mac version 1.3.7
Mac OSX Version 10.4.11
"ringmod.ny" plugin found on Audacity Team's website
Re: ringmod.ny help?
Post by steve » Mon Jul 23, 2012 11:05 pm
What's your question? Is it that you can't get ringmod.ny to work, or that you can get it to work but it does not sound like you want it to sound?
If the problem is that it is not producing the effect that you want, please post either a short sample, or a link to a short sample of the type of effect that you want.
