recording problem
staffraj
recording problem
Post by staffraj » Wed Jul 18, 2012 8:22 pm
Hope someone can help me with this; when i record a 2nd track, it includes the 1st track on it,recording a 3rd track includes the other 2 and so on. Is there a setting i need to change?
Thanks for any help
DVDdoug
Forum Crew
Re: recording problem
Post by DVDdoug » Wed Jul 18, 2012 9:26 pm
How/what are you recording and what source/input have you selected? If you are recording "Stereo Mix" or "What-U-Hear", then you are are going to record mixed sounds, otherwise, you should only be recording one thing at a time.
Post by kozikowski » Wed Jul 18, 2012 11:10 pm
The settings for recording internet audio are different from the ones for overdubbing, sound-on-sound and live recording. You need to be sure you're recording from a real physical device like Mic-In or Line-In, not one of the made up "fake" devices like Stereo Mix.
Here it is. I thought we wrote simple recording instructions.
http://manual.audacityteam.org/help/man ... rding.html
