Program Won't Open
Help for Audacity on macOS.
tjefferson84
Program Won't Open
Post by tjefferson84 » Mon Jul 16, 2012 5:35 pm
Hello, I am trying to complete a school assignment that requires to use this program. It was working for a while and now it will not open anymore. I really need to figure out what's going on ASAP so I can complete my schoolwork. Attached is a screenshot of what happens every time I try to open the program. Thanks :D
Tjefferson84
Screen Shot 2012-07-16 at 1.34.13 PM.png (602.13 KiB) Viewed 764 times
billw58
Re: Program Won't Open
Post by billw58 » Mon Jul 16, 2012 9:50 pm
Your system has Waves plugins installed, which Audacity has problems with. Either remove those plugins, or follow the instruction on this page
http://wiki.audacityteam.org/wiki/User: ... ces_on_Mac
to disable VST and Audio Unit plugins.
-- Bill
tjefferson84
Post by tjefferson84 » Wed Jul 18, 2012 5:06 pm
THANK YOU THANK YOU THANK YOU THANK YOU THANK YOU!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :D :P :) :lol: :mrgreen: :D :D :D :D :D :D :D :D :D
