I have installed Audacity 2.x from the dmg on my OSX 10.6.8. I'd like to know if there are plugins available to add reverb. I've been creating and cleaning my Audacity recordings, then bringing them into Garageband for enhancements. Obviously, I'd like to avoid the extra steps involved.
Thanks!
Reverb plug-ins
Laughterman
- Quality Assurance
Re: Reverb plug-ins
GVerb is included in the Effect menu, but you may find it more convenient to obtain a third-party plug-in for reverb.
See this page for some ideas http://wiki.audacityteam.org/index.php?title=GVerb .
