Need help
RunrigCorvusCoraxFan
Need help
Post by RunrigCorvusCoraxFan » Fri Jul 13, 2012 11:09 pm
I've downloaded the new version; and this has been a problem since the beta. I transferred a cassette, using my stereo, (I can copy to USB stick). I have the CD of the cassette, so I checked the wavelength of the song, and want the cassette to match. The song starts at 0.50, with the song on the 0, on the CD version. Now I have tape transferred, and want the song to start at the 0, when I try to drag, it highlights a portion, and not like the old audacity, when you drag, and you can delete the parts you want to delete. :roll:
Re: Need help
Post by Gale Andrews » Sat Jul 14, 2012 3:11 am
Uncheck the Snap To checkbox bottom left.
Press Stop.
