Audacity 2.0.1 WONT OPEN! PLEASE HELP!
Help for Audacity on macOS.
patrickreza
Post by patrickreza » Thu Jul 12, 2012 4:57 am
Hey guys, so I've tried the audacity.cfg method and audacity is still bouncing
around on the dock not opening. Making me force quit it.
Please help! IN DESPERATE NEED!
Macbook Pro
10.7.4
2.8 Intel i7
8GB Ram
patrickreza
Re: Audacity 2.0.1 WONT OPEN! PLEASE HELP!
Post by patrickreza » Thu Jul 12, 2012 7:41 am
also tried the Portable Settings option
Post by steve » Thu Jul 12, 2012 3:14 pm
If there is an audacity.cfg file, try editing it so that it has only this information in it.
This will disable Audiounits and VST effects:
Code: Select all
NewPrefsInitialized=1
[AudioUnits]
Enable=0
GUI=0
[VST]
Enable=0
GUI=0
Rescan=0
Probably best to remove the Portable Settings folder and do this with the normal audacity.cfg file (or a new file in the location where the audacity.cfg would normally be).
patrickreza
Post by patrickreza » Thu Jul 12, 2012 4:11 pm
did that too. in applcation support > audacity and i created a portable settings > cfg file still just bouncing around looking all stupid and whatnot
billw58
Post by billw58 » Thu Jul 12, 2012 4:23 pm
The file must be called "audacity.cfg". You say "created a portable settings > cfg file"; just making sure you name the file correctly. You can put it in ~/Library/Application Support/audacity, or you can put it in a Portable Settings folder that is in the same directory as the Audacity application. As Steve notes, probably best at this time to put it in the normal location.
--Bill
patrickreza
Post by patrickreza » Thu Jul 12, 2012 4:30 pm
billw58 wrote:The file must be called "audacity.cfg". You say "created a portable settings > cfg file"; just making sure you name the file correctly. You can put it in ~/Library/Application Support/audacity, or you can put it in a Portable Settings folder that is in the same directory as the Audacity application. As Steve notes, probably best at this time to put it in the normal location.
--Bill
yeah that's exactly what i did. both the portable settings > audacity.cfg and in ~/Library/Application Support/audacity/audacity.cfg
still get NOTHING. :(
I know it has to do with my WAVES and Guitar Rig plugins but this is freaking annoying because the code is supposed to open it with no VST or AU scans.
billw58
Post by billw58 » Thu Jul 12, 2012 7:54 pm
Please delete the Portable Settings folder and its contents, then try again.
If that does not work please post the contents of the audacity.cfg file you are using. Make a copy, rename it "audacity.cfg.txt" and attach it to a message.
-- Bill
