I know n read all the info on audacity , but can't seem to figure out how to record my vinyls... I have a Stanton turntable, DJM600 mixer, and Traktor audio dj 10.
Also a macbook pro with one line in jack. Got the RCA to jack cable, and pretty much stuck here. Any help would be appreciated...from the setup to settings.Thanks!
Need help from the start :(
bornapartmusic
waxcylinder
Re: Need help from the start :(
This tutorial set from the manual describe sthe process: http://manual.audacityteam.org/help/man ... to_cd.html
bornapartmusic
Thanks but the whole tutorial is just something I can't get anywhere with.....Im sitting in front of my mac and nothing looks or acts as it supposed to being described in the tutorial.
"nothing"? Is you computer turned on?bornapartmusic wrote:Im sitting in front of my mac and nothing looks or acts as it supposed to
Do you have the right version of Audacity? The manual and tutorials refer to the current version of Audacity which is available here: http://audacityteam.org/download/
