Issue on Start Up
Help for Audacity on macOS.
ChasenP
Issue on Start Up
Post by ChasenP » Tue Jul 10, 2012 4:08 pm
Hey all,
Sometimes when I start up Audacity any audio that I record ends up notching. If I close and reopen the program, the problem with go away about half the time. I often have to close and reopen a few times before I can record clean.
Thoughts? Help?
Thanks
Re: Issue on Start Up
Post by steve » Tue Jul 10, 2012 4:26 pm
