Unable to open target file
Help for Audacity on macOS.
PGA
Re: Unable to open target file
Post by PGA » Tue Jul 10, 2012 7:30 pm
kozikowski wrote:...MP3, as I understand it, doesn't support multiple stereo track export.
Koz,
I've just done a File > Export of two stacked stereo tracks to MP3 (CBR, 192Kbps). It worked OK.
