Getting Started
fundraiser
Getting Started
Post by fundraiser » Tue Jul 10, 2012 3:41 am
It has been years since I last used Audacity. I just downloaded 2.0.1 to my windows 7 computer. I am not computer literate. I tried to use the tutorial but can not get Audicity to record from my streeming computer. I went to the sound control panel site but nothing matches what is in the tutoral. Any help would be appreciated. :)
Re: Getting Started
Post by steve » Tue Jul 10, 2012 4:53 am
Start here: http://wiki.audacityteam.org/wiki/Mixer ... _Issues#cp
If you get stuck, describe where you're stuck.
