pulling voice
pulling voice
I have a recording with a lot of background noise and I would like to edit the file so the voices are more clear. What is the easiest way to do this?
Re: pulling voice
If you want a good, clear recording, the easiest way is probably to re-record with less background noise.
If you want to try noise removal, see here: http://wiki.audacityteam.org/wiki/Noise_Removal
