record button grey
Help for Audacity on macOS.
LNrecords
record button grey
Post by LNrecords » Tue Jul 10, 2012 12:36 am
Mac Os 10.6
latest version of Audacity
I am trying to record sound from a lecture that is on the internet. So a system recording.
I have the Mac sound preferences set up with Soundflower 2 as the imput and output sound system
I save the recording and the record button goes grey.
I was able to make a trial recording. Then I tried to follow some instructions to set up the preferences. No matter how I change the preference, nothing changes. Wish I could send you a photo to show you the set up.
PGA
Re: record button grey
Post by PGA » Tue Jul 10, 2012 5:45 am
Audacity includes in-built screen grabbing. Look under Help > Screenshot Tools. That might be a different command on your Mac: I look through Windows!
