Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
Docfoster
Post
by Docfoster » Sun Jul 08, 2012 10:03 pm
Hi,
Windows 7.
Recording LPs.
The sound is all swishy and intermitent and consequently unlistenable.
The sound coming out of the laptop's headphone socket during monitoring of the raw signal from the TT sounds fine.
Presumably some basic setting in Audacitty that I've missed...?
Any pointers massively appreciated.
Many thanks,
Ben
- Site Admin
Post
by steve » Sun Jul 08, 2012 10:06 pm
Is the "swishy" sound in the original Audacity recording (played in Audacity) or only when you play the exported file?
Docfoster
Post
by Docfoster » Sun Jul 08, 2012 10:18 pm
Thanks.
It's the original audacity recording (red book CD quality settings in audacity).
Post
by kozikowski » Sun Jul 08, 2012 10:43 pm
- Site Admin
Post
by steve » Sun Jul 08, 2012 11:13 pm
kozikowski wrote:Could you be a victim of Windows Conferencing?
I wish you'd stop calling it "Conferencing". There is no such setting in Windows as "Conferencing" so users will not e able to find such a setting. The settings in Windows are called "Enhancements". It may be different in Mac OS X, but in Windows the tab says "Enhancements" and the options are collectively called "Sound Effects". There is no mention of "Conferencing" anywhere.
Post
by kozikowski » Mon Jul 09, 2012 5:17 am
No, but that's exactly why it's there and I always point to the instructions.
Docfoster
Post
by Docfoster » Mon Jul 09, 2012 6:20 am
Thanks for the info guys.
Whatever the term, i'll look into it later...
Ben
