Making mp3 Exports Smaller
Help for Audacity on macOS.
lacart
Post by lacart » Sat Jul 07, 2012 3:20 pm
I work with an organization where I record one hour sessions of news for blind people to listen to. We use Yousendit.com to send the files, but it only allows 50 MB to be sent at a time. My files are about 53-56 MB when I export them to mp3. I have been cutting them in half and sending two files, but no one else who records has this problem, so I want to know how to reduce the size of the files a little. I have already changed the default sample rate to 22050 and the default sample format to 16-bit in Preferences, and this hasn't helped. What's wrong?
Re: Making mp3 Exports Smaller
Post by steve » Sat Jul 07, 2012 4:04 pm
Make your recordings in mono. (select "mono" in the Device Toolbar before you start recording).
You can also convert tracks from stereo to mono using "Tracks menu > Stereo track to mono".
Record at 44.1 kHz, 32-bit float.
In the MP3 export options, try "Preset: Medium"
(http://manual.audacityteam.org/manual/h ... tions.html)
This should produce a file that is around 35 MB for a 1 hour recording in reasonably good quality.
Post by kozikowski » Mon Jul 09, 2012 5:24 am
I don't think we have "medium."
Oh, I see. It's under presets. But those are all variable bitrate. Koz
Screen shot 2012-07-08 at 10.31.28 PM.png (32.62 KiB) Viewed 1927 times
Post by steve » Mon Jul 09, 2012 12:30 pm
Yes, it's here:
For mono speech based recordings this will give very good sound quality and still come in at well under lacart's 50 MB limit.
The bit-rate is likely to be substantially lower than the quoted figure as the setting is based on "perceived quality" rather than kbps. The kbps figure is a guide to what the average bit rate will be for stereo music. For mono speech it is likely to work out at around 70 to 80 kbps.
