What System Profiler "Kind" Applies to Audacity.app v2.0.1
Help for Audacity on macOS.
dgkanter
Post by dgkanter » Thu Jul 05, 2012 7:04 pm
[MacBookPro6,2, Mac OS 10.6.8]
I'm getting ready for moving from Snow Leopard to Mountain Lion and am checking all my applications for life in that non-Rosetta environment. (I've skipped Lion.) I find the entry for Audacity.app (v2.0.1) in the System Profiler has nothing in the Kind column. Shouldn't that be included in the metadata (or whatever) for the app? Regardless, which "Kind" is applicable?
Re: What System Profiler "Kind" Applies to Audacity.app v2.0
Post by Gale Andrews » Fri Jul 06, 2012 9:24 am
Audacity 2.0.1 is a Universal Binary, so it works on Intel Mac (without Rosetta) and PPC Mac.
dgkanter
Post by dgkanter » Fri Jul 06, 2012 2:00 pm
Gale Andrews wrote:Audacity 2.0.1 is a Universal Binary, so it works on Intel Mac (without Rosetta) and PPC Mac.
Thanks. (Trust that "kind" information will be coded into a future release.)
David
Post by Gale Andrews » Sat Jul 07, 2012 9:00 pm
I've added a bug report http://bugzilla.audacityteam.org/show_bug.cgi?id=543 . The Kind information is there, but only if you drill through the package contents.
We are very short of Mac developers so please don't be surprised if this is not fixed for some time.
dgkanter
Post by dgkanter » Tue Jul 10, 2012 4:08 pm
Gale Andrews wrote:I've added a bug report http://bugzilla.audacityteam.org/show_bug.cgi?id=543 …We are very short of Mac developers so please don't be surprised if this is not fixed for some time.
Thanks, again. I appreciate that it's at least now on record.
David
