Hi all,
I am working on a freeware gui using nr(c),gnp(c) and autoloop(c) from nick Appleton.
The missing part in these program's is: load wave file,soundfinder.ny and export labels.
I asked to add these last two commands in apply chain and edit chain.
Is there any one who has an idea how to integrate this in Visual FoxPro 9 or run it with a dos like command from a program.
Programming is to difficult for me. In foxpro it works, because I know something for it, but it is also hard for me.
Kind regards,
Jan Flikweert
Soundfinder and export labels
janflorijn
Re: Soundfinder and export labels
SoundFinder is available in Chains in the latest version of Audacity (2.0.1).
It would be possible to modify sound finder so that it exports to a file as well as producing labels.
Audacity is designed as a GUI program so it will be difficult to integrate it into some other program.
