Error on sliding time scale/pitch shift - SOLVED
Re: Error on sliding time scale/pitch shift - SOLVED
Post by Gale Andrews » Sun Aug 26, 2012 10:08 pm
Excellent. Thanks for your willingness to test patched builds for us!
