How to preserve original file characteristics when joining?
Help for Audacity on macOS.
paulgk
Re: How to preserve original file characteristics when joini
Post by paulgk » Tue Jul 03, 2012 2:14 am
@steve:
Thank you for both of your helpful responses. Between your suggestions and those of others in this thread, I believe that all bases have been covered and that I'll be able to import/cut/paste/export with confidence, knowing that I'll be preserving the characteristics of the original files.
Cheers,
Paul
