Double arrow seems to stop me from recording?
Help for Audacity on macOS.
audioapap
Post by audioapap » Sat Jun 30, 2012 3:44 am
Double arrow seems to stop me from recording? in the time line, there is a double arrow that I just can't seem to remove.. i am trying to do an append record and it will not allow the cursor to more in record or play?
It was working but there was a power failure earlier while I was working?
thanks
billw58
Re: Double arrow seems to stop me from recording?
Post by billw58 » Sat Jun 30, 2012 2:56 pm
You have probably accidentally selected a very short region in the track. Click the Skip to End button, then try again.
-- Bill
PGA
Post by PGA » Sat Jun 30, 2012 3:08 pm
More likely you have selected the Timeshift tool instead of the Selection tool in the Toolbar.
