Audacity Recording Freeze at 38m 47.5s: Win7
PGA
Re: Audacity Recording Freeze at 38m 47.5s: Win7
Post by PGA » Fri Jul 13, 2012 7:31 pm
justinrpg wrote:
steve wrote:
justinrpg wrote:the limitation of a 32bit OS is NOT 3GB!!!
We probably don't need all of the "!!!"
To clarify the situation, see here: http://msdn.microsoft.com/en-us/library ... ory_limits
that link leads to "unable to fulfill service request" error message!!!
Not on my system, it doesn't! [note the single "!" !]
otwo_pipes
Post by otwo_pipes » Fri Jul 13, 2012 9:12 pm
I raised this post and the problem is Audacity Freeze with audio cache enabled.
I did not bother replying to the memory limit originally asserted because:-
i) My system only has 2GB
ii) My Win7 system was using around 300-500MB of RAM so there was oddles to do whatever Audacity required
iii) Recording at 24/192, takes around 20 minutes to crash, i.e. all RAM fully utilised
iv) I thought it was irrelevant to the problem of the post.
I still think the amount of RAM fitted to the mother board is irrelevant to the problem of the post however, as you cannot read the link, allow me to assist:-
Version Limit on X86 Limit on X64
Windows 7 Ultimate 4 GB 192 GB
Windows 7 Enterprise 4 GB 192 GB
Windows 7 Professional 4 GB 192 GB
Windows 7 Home Premium 4 GB 16 GB
Windows 7 Home Basic 4 GB 8 GB
Windows 7 Starter 2 GB N/A
Apologies for not being able to format as a table
Have a nice day :)
Post by Gale Andrews » Sat Jul 14, 2012 5:43 am
justinrpg wrote:
audino wrote:With your system Win7 x32 you can install max 3GB of ram so it might still not enough for your set up.
That is a limitation for the 32bit system unless you upgrade (install from scratch new OS) to 64bit.
that is not true, I have a 32bit Windows 7 ultimate and 4GB of ram... it allows me to use 4GB of ram on a 32 bit operating system!!! the limitation of a 32bit OS is NOT 3GB!!!
You can install 4 GB of RAM but perhaps what audino means is that the maximum address space of any 32-bit application like Audacity is 3 GB. And for Audacity as we distribute it, it's 2 GB because we don't set IMAGE_FILE_LARGE_ADDRESS_AWARE to yes (and even if we did, the user would have to set the 4-gigabyte tuning (4GT) feature for Audacity themselves thus:
http://msdn.microsoft.com/en-us/library ... 85%29.aspx ).
When I was crashing on editing yesterday with Audio Cache on, I would of course have been very close to that 2 GB limit, though that doesn't excuse the crashes.
If Dennis wants to try a build with IMAGE_FILE_LARGE_ADDRESS_AWARE set to yes and enable 4GT for himself, I could make such a build as an experiment, though I don't see why it would help crashes when Audacity isn't using anything like that amount of RAM, which I think is true for Dennis.
Post by Gale Andrews » Sat Jul 14, 2012 5:53 am
steve wrote:
Gale Andrews wrote:Can you give your exact steps in View History?
  1. View > History
  2. Discard
Yes, obviously ;) but I meant exactly what item in the list are you selecting before you discard?
Are you still saying:
1 Generate 30 minutes mono 44.1/32
2 You now have d00 and d01
3 Undo
4 You still have d00 and d01
5 Generate another 30 minutes mono 44.1/32
6 You now have d00, d01, d02
leaves you with d00, d01 and d02 at step 6? If so, was this with audio cache on or off?
I don't like it when our favourite program does different things on different machines. :?
Post by steve » Mon Jul 16, 2012 2:30 pm
Gale Andrews wrote: leaves you with d00, d01 and d02 at step 6?
My mistake. Nautilus shows d00, d01 and d02, but if the view is refreshed when step 5 (generate the new 30 minute track) is completed, d00 disappears leaving just d01 and d02.
otwo_pipes
Post by otwo_pipes » Mon Jul 16, 2012 9:04 pm
@Gale:
Of course I will assist. I would be only too pleased to assist but I do not see what benefit this could be when I only have 2GB of RAM in either of my systems. Just advise me as to how you would like to proceed and I will try to assist.
I also believe Audacity is only using large amounts of RAM when I have the audio cache enabled and the reserved RAM set low, i.e under 16MB in XP and under 100MB in Win7.
Post by Gale Andrews » Wed Jul 18, 2012 6:26 am
otwo_pipes wrote:@Gale:
Indeed, though since the Audio Cache feature does not behave correctly on some machines it is not completely inconceivable that setting large address aware could make a difference; for example if there was some coding oversight that assumed this flag was set.
But if someone joins the discussion who has 4 GB system RAM or more obviously that is a much more interesting case to test. Making more tests myself is not a priority right now given the feature is to be hidden.
otwo_pipes
Post by otwo_pipes » Thu Jul 19, 2012 8:28 am
But if someone joins the discussion who has 4 GB system RAM or more...........
Okay, if we both put this one on the 'back burner' when I upgrade my desktop we can revisit the issue.
