audacity 2.0
coolmanhuber
audacity 2.0
Post by coolmanhuber » Tue Jun 26, 2012 2:45 am
Every time I try to run Audacity 2.0 my computer reboots. I uninstalled the program, downloaded version 2.0 again and re-installed. Same result. Prior to today I have had no problem running the program. I installed Audacity from the file audacity-win-2.0.exe. I am running WindowsXP with SP3 installed.
Re: audacity 2.0
Post by Gale Andrews » Tue Jun 26, 2012 5:44 am
Please see http://manual.audacityteam.org/man/FAQ:Errors#reboot .
If this has only just happened, you can see if Windows Device Manager has an option to roll back to a previous sound card driver. Windows Update could have changed or modified the drivers or something else that affects them . See http://wiki.audacityteam.org/wiki/Updat ... ows_Update .
Or simply try a System Restore back to before the problem started. See http://support.microsoft.com/kb/306084 .
thor21344
Re: audacity 2.0
Post by thor21344 » Tue Jun 26, 2012 2:53 pm
And also did yuou buy any chance install any other programs latley that could be causing a conflict, just a thought, Marty
coolmanhuber
Re: audacity 2.0
Post by coolmanhuber » Thu Jun 28, 2012 1:26 am
I did a System Restore to two different dates. Problem was not solved, but additional problems (which I won't go into) were created. I contacted Creative Technologies and they weren't much help. The audio card is so old they probably don't have any drivers for it. My final solution is the one I hate but always works: re-install all software.
coolmanhuber
Re: audacity 2.0
Post by coolmanhuber » Mon Jul 09, 2012 10:02 pm
I reinstalled my operating system and reinstalled Audacity 2.0. When I try to run Audacity now, I get a different message:
"This application has failed to start because the application configuration is incorrect. Reinstalling the application may fix this problem."
I reinstalled Audacity which didn't help. I suspect this might have something to do with a driver for my Sound Blaster sound card. I contacted Creative Technologies about this, but the sound card is so old that they no longer have the drivers for this card. I have software for this sound card, but the last time I tried to reinstall it, it messed up my system so badly I had to reinstall the entire operating system, so I'm very leery about doing this again.
Re: audacity 2.0
Post by Gale Andrews » Tue Jul 10, 2012 3:21 am
coolmanhuber wrote:I reinstalled my operating system and reinstalled Audacity 2.0. When I try to run Audacity now, I get a different message:
You can solve the Audacity problem by installing the appropriate 32-bit or 64-bit Microsoft Visual C++ 2008 SP1 Redistributable Package (x86) from this FAQ: http://manual.audacityteam.org/o/man/fa ... html#probs .
Exactly what make and model is the SoundBlaster card?
coolmanhuber
Re: audacity 2.0
Post by coolmanhuber » Thu Jul 12, 2012 3:44 am
The sound card is Sound Blaster Live! Model No. SB0100 from Creative Labs.
coolmanhuber
Re: audacity 2.0
Post by coolmanhuber » Thu Jul 12, 2012 3:47 am
Where on the site you quoted do I find this package?
Re: audacity 2.0
Post by steve » Thu Jul 12, 2012 3:59 am
coolmanhuber wrote:Where on the site you quoted do I find this package?
Read the text in the blue/green box: http://manual.audacityteam.org/o/man/fa ... html#probs
Re: audacity 2.0
Post by Gale Andrews » Thu Jul 12, 2012 4:54 am
coolmanhuber wrote:The sound card is Sound Blaster Live! Model No. SB0100 from Creative Labs.
If your Sound Blaster drivers crash XP you may have to look around for drivers on the internet, but be very careful (and don't pay any money or install software that says it will detect what you need). It is possible that as you have updated to XP3 SP3 you need slightly later drivers (or even earlier - these things happen).
I suggest you see if you need this Creative Hotfix (Live! 5.1 web release ):
http://support.creative.com/Products/Pr ... tegoryID:1
then if not, possibly consider if for example this driver will help you:
http://members.driverguide.com/driver/d ... rid=129467 .
